Post your Microsoft Automatic bios Update Hardware ID`s
    • 22012
    Some of the newest laptops have the capability to automatically update the bios from Microsoft update.
    If its enabled there will be Hardware ID listed in device manager under
    Firmware - System Firmware - Details - Property - Hardware ID`s - UEFI\RES_
    Example: UEFI\RES_{5E28725C-AA01-4AAA-9E44-414B5EE2EA44}
    Entering the hardware ID {without the curly brackets} at https://www.catalog.update.microsoft.com/Home.aspx
    will show a list of available updates.The downloads are cab files,they can be extracted with winrar or 7-zip.
    Each extracted cab will have an inf file and an update capsule. Check the inf to make sure it has the same hardware ID.The update can be installed on a runnig machine,at your own risk of course,or used to fix a bios dump by hex editing.
    It can be a useful way to find new and older updates.
    Post your hardware ID`s with the laptop make and model number ,for example:
    Samsung NP950QDB
    • 22012
    Re: Post your Microsoft Automatic bios Update Hardware ID`s
    Microsoft Surface Pro 4
    UEFI\RES_{137F5D0A-B53B-45B3-AA77-8E6671ACE16B}
    • Bonzas
      • 474
      • Indonesia
      can i use this methode to search unknown laptop from china ? from bios backup not from OS ?
        • 22012
        Maybe,lets see the backup
        • Bonzas
          • 474
          • Indonesia
          Here's for example, i got cheap laptop from china. No brand no sticker on the case. The only code that i found on the board is DY600MB_VER1.21, i already try some methode from github. Maybe you can help find some info from the backup
            • 22012
            Sorry but nothing was found.
            • Bonzas
              • 474
              • Indonesia
              Ah okay, thanks for your time
              • mikeybass
                by mikeybass
                04-23-2025, 04:30 PM
              • al3m0di
                Update bios EFCN58WW to EFCN59WW
                by al3m0di
                Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                The BIOS version is EFCN58WW.
                When I turn on the device, it displays the message:
                "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                I've tried
                07-29-2024, 10:32 AM
              • capoplays
                Help with BIOS update on Dell G15 5515 after chip replacement
                by capoplays
                Hey everyone,
                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                When I check the BIOS using the F12 menu Flash...
                10-24-2025, 06:53 AM
              • ahmypc
                Microsoft Surface Pro 4 Bios Update Issue
                by ahmypc
                The device that has not received an update for a long time cannot update the new ME Region. That's why touch doesn't work. Bios file cannot be opened with Flash Image Tool. Additionally, I am attaching the update file downloaded to the device and the original bios file. I would be glad if you help....
                09-21-2023, 02:14 AM
              • 0xx
                2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                by 0xx
                Hi folks,
                My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                I assumed that Windows Update was interrupted due to closing...
                09-14-2025, 03:46 PM
